66, 427 crankshaft, where to purchase - NCRS Discussion Boards
  • William B.
    • April 30, 1975
    • 939
    I have been looking at NAPA and Summit web sites, can not find crankshafts or engine kits for a 66 427, am I looking in the wrong place?
    • 43219
    Re: 66, 427 crankshaft, where to purchase
    William------
    Here's one available from Summit:
    However, if you have a steel 454 crank that's good, I'd just go with that. There's no substitute for cubic inches.
    • Clem Z.
      • January 1, 2006
      • 9427
      William------
      you will need to clearance the block to use the 454. the power difference is nothing but amazing.
      • Clem Z.
        • January 1, 2006
        • 9427
        this is important to understand but any good shop should know this. "Requires Narrow Bearings" because of the larger than stock radius in the journal corners
        • Larry B.
          • October 21, 2012
          • 71
          I have serveral 396 427 cranks they are the same casting #6223 I can also do a complete kit. What do you want in a kit. Ican also do all machine work on a Rottler F65 CNC machine. Give me a call 541-218-7754
