72 Headlights - NCRS Discussion Boards
72 Headlights
  • Rey S.
    • April 1, 1995
    • 277
    72 Headlights
    My right side headlight top(?) appears to have a twist (warp) to it. 3 corners align almost perfect but then the front inner remains +/- 1/4" high. If I lower the closing adjustment then the outer corner becomes lower by an equal amount. Do I have to live with this or am I missing something with the adjustments ? or do I settle for a happy (?) medium ?
    Rey Stenhouse (26007)
    • 6941
    Re: 72 Headlights
    Ray, is it possible that maybe a shim will work under the mounting (washer)?
      • 3415
      Re: 72 Headlights
      Hi Rey,
      I believe that Edward's reply might be the answer.
      If not, I remember that there's a bit of up/down adjustment in the 2 bearing assemblies for the door's pivots. They're item #26 on UPC 12, Sheet A2. They may allow you tip the door a bit to get that last corner in place.
      Good Luck!
      • Rey S.
        • April 1, 1995
        • 277
        Re: 72 Headlights
        I am working on that senario now.
        • Michael F.
          • July 24, 2011
          • 29
          Re: 72 Headlights
          I have the same issue. Please let us know how you resolved it and how it turned out.
