Power steering problem l36 - NCRS Discussion Boards
+ More Options
Posts
  • James B.
    • June 21, 2009
    • 28
    My power steering works when cold, after driving 10 min or so or a high rpm run threw the gears I loose P/S. I have a new pump, new control valve, and new lines , can anyone make explain this condition. The only part to change is the cyln.
  • Terry B.
    • August 31, 1999
    • 607
    Re: Power steering problem l36
    Hi James,
    I'm bringing you back to the top of the list. I have a similar problem with my PS after it warms up.(Noisy when you turn) It's not new and I thought I might need to replace something. I'm interested in your responses.
    Terry Buchanan
    Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
    Corvettes Owned:
    1977 Coupe
    1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
    2003 Electron Blue Coupe
    2019 Torch Red Grand Sport Coupe
    • Paul O.
      • August 31, 1990
      • 1716
      James
      I have a question for you why did you replace all of those items was there a problem before?
      • James B.
        • June 21, 2009
        • 28
        I am having the same problem after changing all the parts, I will be changing the cyln next,
        • Paul O.
          • August 31, 1990
          • 1716
          James
          That is why I ask the question if you had no problem before you started the parts replacement then it could have been 1 of the items you replaced. With that being said sounds like your cylinder the seals inside are sealing when the oil is thicker cold then when the oil thin out when heated. So I would say your cylinder is the problem.
          • James B.
            • June 21, 2009
            • 28
            I just changed the cyln. that was it
            • Terry B.
              • August 31, 1999
              • 607
              Hi James,
              Glad you solved the problem. Were you replacing all the power steering parts with replacement parts or parts that were rebuilt originals and if so, whom did you use?
              Terry Buchanan
              Corvettes Owned:
              1977 Coupe
              • James B.
                • June 21, 2009
                • 28
                I used replacement parts rebuilt by Corvette sports in Sheboygan, 920-467-2833 he ( Dick) will rebuild your originals.
                Jim 69 L36, 2008 conv.
