1959 corvette steering column - NCRS Discussion Boards
  • Patrick M.
    • July 20, 2012
    • 50
    Can anyone tell me what is the color of the steering column on a 59 vette. The interior of my car is red. When painted does the color of the column continue to the steering box? Does the column come out from the box itself? Thanks Pat McPherson 55168
  • Donald H.
    • November 2, 2009
    • 2594
    Re: 1959 corvette steering column
    Page 13 of the TIM & JG says 'Column assembly on 1959-60 is gloss interior color extending at least several inches below hub (remainder of column is black to steering gear). I just put my assembly back in my 1960. It is painted interior color down about 6 or 8 inches then black from there to the gear box.
    The other steering column is pressed into the gear box and is not intended to be removed. You can however take the guts out of the gear box which includes the steering shaft which includes the worm gear.
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
    • John T.
      NCRS Financial Officer
      • January 1, 1983
      • 293
      Also note that the transition from interior color to black was not masked. The interior color simply faded away.
      Hope this helps also.
      John
      • Patrick M.
        • July 20, 2012
        • 50
        Thanks for the information. Just another way GM was sloppy in their production. Pat McPherson
        • Joe M.
          • April 30, 1990
          • 1343
          John is correct on the transition from interior color to black.
