1962 oil pan - NCRS Discussion Boards
1962 oil pan
  • Grant G.
    • February 24, 2012
    • 1
    1962 oil pan
    Could someone direct me to past discussions or archives regarding the correct oil pan for a 62 340 hp.
    tks
    zac
  • Edward L.
    • 278
    Re: 1962 oil pan
    tks
    zac
    The correct oil pan for a solid lifter 1962 (340 and 360 hp) will have the following configuration:
    The bottom will have three smooth steps with the drain plug in the middle of the deepest sump and two dimples at the rear of the second step.
    The sides of the pan will have one reinforcement rib approximately 6 3/4" long. It is often referred to as the "trap door" pan. There will be evidence of spot welds where the trap door baffle was installed.
    Ed
    • Robert K.
      • July 31, 1984
      • 213
      Re: 1962 oil pan
      Do a search on trap door and you'll find several. Be warned that there is a front seal size issue (pre 74 and after I think). Someone needs to chime in here because I don't understand it myself. Would someone tell us the depth of the seal for the correct 62 - 340 pan? Is it the same as the 61?
      • Gary C.
        Administrator
        • October 1, 1982
        • 17773
        Re: 1962 oil pan
        Grant,
        Recommend read the FAQ on how to Search. Rich M. wrote very good information on how to use key words with the Boolean search feature.
        Gary
        NCRS Texas Chapter
        https://www.ncrstexas.org/
          • 43259
          Re: 1962 oil pan
          Robert-----
          All original oil pans used on 1955-74 Corvette small blocks used a 2-1/4" front gasket radius. All of these pans had 7 digit part numbers. SERVICE pans after about 1975-76 for 1955-74 Corvette small block applications used a 2-3/8" front gasket radius. These pans all had 6 digit part numbers. Unfortunately, the part numbers usually do not appear on a pan. So, one has to check the front gasket radius before one purchases gaskets. Installed on the engine it's very difficult, if not impossible, to discern which front seal is installed. The front gasket thickness for all 1955-74 Corvette small blocks was 0.22". The front gasket thickness for all 1975+ pans as well as 55-74 SERVICE pans after about 75-76 is 0.41".
          • Robert K.
            • July 31, 1984
            • 213
            Re: 1962 oil pan
            Thanks Joe, I wish I knew that before Carlisle.
            • Tom P.
              • April 1, 1980
              • 1815
              Re: 1962 oil pan
              Just one quick added comment.
              The 55 ONLY pan is all by itself------------------one year, one year only.
              The reason is because 55 V8 blocks (both pass car and Vettes) DID NOT have the pad for an oil filter. Thus, the left rear corner of the block AND pan were a different shape. That's what makes the 55 pan a one year only. A 55 pan CANNOT be used on a 56-later block and vice versa.
              • Bruce B.
                • May 31, 1996
                • 2930
                Re: 1962 oil pan
                The current FelPro engine gasket set I got for my 327 contains seals for both pan configurations and the proper way to measure the pan to determine which seal to use.
                Fel Pro part number is KS2600.
                  • 43259
                  Re: 1962 oil pan
                  Tom-----
                  Yes, and there actually was never a 2-3/8" front gasket radius oil pan for 1955. GM never offered such a pan in SERVICE.
