70 LT1 Harmonic Balance - NCRS Discussion Boards
  • David S.
    • August 9, 2009
    • 595
    I need to purchase a harmonic balance for my 70 LT1. Is there a particular source that reproduces them better than another? I'm not certain I want to go with a repro but I hesitate with buying a used one for similar money.
    Dave
    • 43248
    Re: 70 LT1 Harmonic Balance
    Dave
    Dave-----
    You can still get this balancer from GM under GM #88960604. However, I believe this balancer has degree marks embossed on the perimeter of the outer ring.
    You can also look for an NOS GM #6272224. This balancer is identical to the one originally installed on your engine.
    • David S.
      • August 9, 2009
      • 595
      As always Thank you Joe!
      Dave
      • David L.
        • July 31, 1980
        • 3310
        The original balancer installed on the 70 LT1 was GM # 3947712 stamped "7712" along with a date code (example: "A 0 F" = Jan. 1970, I believe that the "F" is for the manufacturer). GM # 3947712 was replaced with GM # 6272224 (balancer stamped "2224") in July 1972. The casting number on the back side is "3942538" on both balancers. As Joe mentioned the two balancers appear to be identical except for the stamped numbers.
        Dave
        • Paul O.
          • August 31, 1990
          • 1716
          There is a cast 3942538 balancer on ebay if interested.
          eBay Motors makes it easy to find parts for cars, trucks, SUVs, motorcycles & more. We even offer a massive selection of new & pre-owned classics, hot rods, exotics, vans, ATVs, RVs, boats and more at eBay Motors. Shop for your next vehicle, or start selling in a marketplace with 171 million buyers.
          • David L.
            • July 31, 1980
            • 3310
            Paul,
            The balancer you referred to on Ebay is stamped "2224" and dated May 1975 ("E 5 F").
            Dave
            • William P.
              • August 31, 2003
              • 135
              Damper Dudes , Just google and you will find them . I found them reasonable to deal with .
              Bill
