63-64 steel rims - NCRS Discussion Boards
63-64 steel rims
  • Gary P.
    • May 31, 2005
    • 104
    63-64 steel rims
    Do these rims have the letter K after the size. like 15x5 1/2 K or just 15x 5 1/2. Thanks.
  • Pancho T.
    • July 31, 1993
    • 238
    Re: 63-64 steel rims
    here you go
    • Michael M.
      • February 1, 1993
      • 604
      "K" is the Kelsey-Hayes designation stamped into the wheel. "K" is also used for rim contour designation as is "J', "JJ", and "JK".
      • Doug L.
        • March 14, 2010
        • 442
        The 15 x 5-1/2 J is the 63-64 wheel. The 65 wheel is JK suffix. The profiles are different.
        • Timothy B.
          • April 30, 1983
          • 5186
          Doug,
          The 15x5 1/2 K stamping is the correct 63-64 wheel. The KH stamp should appear on the raised spider by the lug holes along with a GM stamp.
          • Pancho T.
            • July 31, 1993
            • 238
            here are a few more pictures
            • Harry S.
              • July 31, 2002
              • 5297
              Just an FYI, if you find a set and restore them:
              1) check the lug nut holes to be round
              2) media blast the wheels
              3) spray the entire with primer
              4) spray the entire wheel with semi-flat black
              5) only spray the face gloss black or body color
              6) if there is a wheel restoration shop in the area contact them. I had 5 oz of weight on one of mine after the shop fixed the wheels (run out), 2 needed no weight, 1 was 1.25 oz, one was 1.50 oz and one was 2.25 oz.
              Good luck!
                Michael -
                To clarify, the "K" in the "15 x 5-1/2K" stamped on the rim section under the tire is strictly the SAE rim section profile identifier; Kelsey-Hayes is identified by their circular logo stamped adjacent to it. The other large logo is for the Tire and Rim Association.
                • Jason S.
                  • January 2, 2012
                  • 72
                  The '63-'64 wheels just started being reproduced, and I bought a set. I have yet to have them mounted and balanced, so I can let the community know how they turn out quality-wise once I get to that step.
                  My car is Daytona Blue - and I intend to put Blackwall tires on the car. Whitewall cars came with the wheels black, and Blackwall cars came with the wheels painted "body color". Now, for the dumb question - Daytona Blue is a metallic color, does that mean the wheels were also painted with the same metallic Daytona Blue paint as the body, or the wheels would have just been some generic shade of "Dark Blue".?
                    Jason -
                    Originally, those wheels were painted Daytona Blue (outer face only), but the paint WAS different - the body color wheel paint was wheel ENAMEL (the only application of enamel on the car).
