'67 SB.
After replacing it - it squeaks. This is the correct length cable from LI Corvette.
So far, the only thing we found was removing tension on the tach assembly stopped the noise.
I removed the cable from the distributor side and spun it with a drill - tach inside was fine, no noise.
When we pulled the cable on the firewall side up a little, the noise at the tach stopped.
The tach also seemed to move a little in the cluster.
So, to me, this said we have too much tension or pressure on the back of the tach housing - only question is how to correct it ??
I'm hoping this stops after some driving and the cable heat cycles in the engine bay.
I think the "gradual S bend" GM intended is hard to do in practice.
Maybe modern materials are stiffer than the originals ? Anyone run into this before ?
Thoughts ? Advice ?
Bob
Thoughts ? Advice ?
Bob
