I have an early 56 distributor without a vacuum advance. where do i hook up to Check changes in Vacuum for timing or carburation?
Early 56 how to check vacuum
Re: Early 56 how to check vacuum
Order Paragon's #755 vacuum fitting - it screws into the hole currently occupied by the hex plug in the rear of the base of the rear carburetor, and it's in two pieces so you don't have to raise the carburetor to get swing clearance to install it; just install the hex part of the fitting first, then screw the separate hose nipple into the fitting.
VacFittiing-Paragon755.pdf- Top
