63E outside mirror questions - NCRS Discussion Boards
    • 6954
    I have a early 63 outside mirror and was wondering what was the gasket mounting material, plastic? and what type of head does the the mounting screw have?Was it a self tapping type?
    I know that the later 63L til 67 tall mirrors had a paper gasket and a allan head screw. Thanks Ed
  • John D.
    • December 1, 1979
    • 5507
    Re: 63E outside mirror questions
    Ed, E63 uses a very thin rubber gasket that is only available if you find a NOS mirror. But the repro will fit just fine although thicker.
    Information sheet enclosed with NOS mirror dated 3-29-62 Part No. 3821965 states the screw is 8-32X9/16. Holds the mirror base onto the bracket. Bracket held onto the door with 2 of 10-12X1/2. They go into the reinforcement.
    The 8-32 x 9/16 screw is a chrome phillips head. SOme say this screw should be allen head but the originals I have seen and the NOS one on my 63 are all phillips head. John
    • Mike M.
      • May 31, 1974
      • 8404
      i've never seen an allen head fastner .mike
        • 6954
        John does the gasket have a lip around the perimeter? Guys thanks for your input Ed
        • John D.
          • December 1, 1979
          • 5507
          Ed, The ones that came with the car had a slight hint of a lip. But you won't find that gasket very easily. Just buy a repro.
          Doc Mike, Call me back.
          • Troy P.
            • February 1, 1989
            • 1284
            I got my correct 63E mirror from a 63 Chevy passenger car. Cheap too. So look there for the gasket and screw.
