transmission paint - NCRS Discussion Boards
transmission paint
  • Wayne P.
    • January 23, 2008
    • 444
    transmission paint
    I would like to be able to touch up my transmission paint . Would their be a particular gray that was used ? My car is a driver so a close match would be good. Maybe a brush epoxy application ? Thanks
  • Dan H.
    • July 31, 1977
    • 1372
    Re: transmission paint
    Hi Wayne, probably the best paint is Krylon Dull Aluminum or whatever the vendors carry now in that type paint. (although not painted originally).
    1964 Red FI Coupe, DUNTOV '09
    • Gene M.
      • April 1, 1985
      • 4233
      Wayne,
      The tranny in not supposed to be painted. Tranny s/b bare aluminum casting. I would suggest to use a water base stripper and remove paint that was applied.
      • William C.
        • May 31, 1975
        • 6037
        I'm with Gene, I've done dozens (hundreds) of transmissions over the last 40 years and none of the aluminum case versions were painted from the factory. The tailhousings were generally a different shade due to being die-cast rather than sand-cast, but neither was painted. I'd suggest a good aluminum cleaner.
        Bill Clupper #618
        • Paul J.
          • September 9, 2008
          • 2091
          Wayne, I agree with others. You should get that grey paint off and see what you've got. If it won't clean up enough to suit you then hit it with Krylon Dull Aluminum.
          Paul
          • Wayne P.
            • January 23, 2008
            • 444
            Thanks all. will get the paint stripper out.
            • Michael G.
              • January 1, 1997
              • 1251
              Scrape.....scrape. It'll go quicker than you think. Purchase a good quality stripper.
