Pertronix Coil - NCRS Discussion Boards
Pertronix Coil
  • Mark S.
    • September 9, 2012
    • 10
    Pertronix Coil
    Just had a Pertronix (basic) ignition installed. I'm going to put on the 40000 volt coil to match. Do I get the 3ohm or 5ohm ??
    1967 327/300 all stock ... Except the breakerless ignition ...
  • Don H.
    • December 1, 1981
    • 1494
    Re: Pertronix Coil
    Mark, I can't answer your question but wonder why you are changing the coil. I have run a Pertronix in both of my cars for years with a stock coil and never had a problem. Good luck, Don H.
    • Bruce B.
      • May 31, 1996
      • 2930
      Re: Pertronix Coil
      I put in a Pertronix many years ago (8-19-99, it was one of the first units they made for my 985 dual point distributor) and it has run perfectly using a stock GM coil.
      And I have put 20,000 miles on the car.
      • Paul D.
        • January 1, 1988
        • 101
        Re: Pertronix Coil
        I have also run the Pertronix with the stock #202 delco coils with no problems..............P..
        • Stuart F.
          • August 31, 1996
          • 4676
          Re: Pertronix Coil
          When I ran the basic Pertronix unit, I too used a stock coil along with the stock ballast resistor. When I changed to the Pertronox II unit, I switched to their 45K volt coil and by-passed the resistor as it called for. Love it.
          Stu Fox
          • Joe C.
            • August 31, 1999
            • 4598
            Re: Pertronix Coil
            I assume that you're using the basic "Ignitor" trigger, and not the "Ignitor II". If so, then you need the 1.5 ohm coil. See this application chart:
            Most unobtrusive is the 40011 (you don't need an epoxy filled coil). Remove the decal and it looks almost like the stock coil. You MUST eliminate the ballast resistor with this setup. Best way to do it is to install a shunt along the back side, and connect the 12v wires in the conventional way. Nobody will know.
