62 Speedometer - NCRS Discussion Boards
62 Speedometer
  • Anthony S.
    • November 1, 1982
    • 1
    62 Speedometer
    The speedometer looks like it reads correctly untill 35 mph and than it will not advance any higher.
    Do you think it is just a lube issue?
  • Philip P.
    • February 28, 2011
    • 558
    Re: 62 Speedometer
    Interesting they normally either do not work or jump around and make a lot of noise. Lubrication sure will not hurt and may fix the problem, while not a difficult task you do get to get familiar with the underside of the dash and the car.
    Phil
    • George W.
      • July 31, 1998
      • 322
      Re: 62 Speedometer
      Tony,
      I would start with disconnect the cable at both ends; remove the cable; clean the cable make sure it is ok (not cracked, frayed or bent); put 30 wt. oil down the cable tube from the top; lube the cable with heave red grease; install the cable; connect and go. Good luck.
      Dr. George
