Overhaul a 1965 power glide transmission - NCRS Discussion Boards
  • Steven L.
    • August 16, 2012
    • 6
    Can someone recommend a good transmission repairman in the SE Michigan
    Re: Overhaul a 1965 power glide transmission
    Steven -
    Powerglides are as simple as automatics get, and parts are plentiful - just about any decent transmission shop should be able to rebuild it. Where are you located?
    • Jeff P.
      • October 21, 2011
      • 287
      Call around, i would check craigslist there was someone on there from Madison Heights doing Trans cheap. Anybody that Races GM cars would be able to help you .( Heads Up Racing )
