power steering problem 1969 L36 - NCRS Discussion Boards
  • James B.
    • June 21, 2009
    • 28
    My power steering wil work when first started( both right and left), then will only work when turning the wheel to the right not to the left.
    • 6941
    Re: power steering problem 1969 L36
    Jim, It sounds like the control valve is on the blitz. or one of the supply hoses is imploaded internally.( This is when the inner layer of the hose claspes and squeezes off the flow of fluid). the smaller dia hoses feed the fluid to the left and right.If the hoses and control valve have not been replaced in a few years I would just do both as the hose are cheap money.
    • James B.
      • June 21, 2009
      • 28
      Thank You Ed parts are on the way
