starter configuration question (C2 and early C3) - NCRS Discussion Boards
  • Anthony S.
    • April 30, 1998
    • 156
    Is the longer bolt that extends from the 4" cover (the cover faces the front of the car when starter is installed) positioned near the Solenoid for all mid-year and C3 cars and 68-72 years (i.e. rather than being 180 degrees from the Solenoid side). There is a short nut that is 180 degrees from this longer bolt position... Thanks for any comments... Tony
    • 43293
    Re: starter configuration question (C2 and early C3)
    Anthony-----
    If you're referring to the starter through bolts, one of these has an untrimmed (i.e. "indented") hex head. The other has a threaded extension. The bolt with this threaded extension is installed at the top of the starter (i.e. closest to the solenoid) and is used to attach the starter forward brace.
