L78 Oil Drain Plug Gasket - NCRS Discussion Boards
  • James W.
    • December 1, 1990
    • 2668
    In the current NCRS TGJM the verbage regarding the oil drain plugs for the base 300, 350 and 365 HP engines states that a white nylon gasket is used between the drain plug and the oil pan. The desciption of the L78 drain plug mentions nothing about a gasket of any type.
    Is the same white nylon gasket, a different type of gasket or nothing at all used between the drain plug and the pan? if there is a gasket I would assume it would be painted engine color as it would have been installed? prior to the engine being painted at Tonowanda... correct?
    James West
  • Gene M.
    • April 1, 1985
    • 4232
    Re: L78 Oil Drain Plug Gasket
    James,
    Typical that the orange paint does not adhere well to the plastic (nylon or delrin material) seal washer. Most are typical white. I have seen replacements in black.
    • James W.
      • December 1, 1990
      • 2668
      Originally posted by Gene Manno (8571)
      James,
      Gene,
      Thanks for the reply. So the same nylon seal washer is used for the L78... this is what I thought but since the TGJM does not mention it specifically for the L78 I thought it may have been different. This would be another item to be corrected for the upcoming sixth edition of the 2014 1965 TGJM.
      Best Regards,
      James West
        • 43247
        Originally posted by James West (18379)
        Gene,
        Best Regards,
        James West
        James------
        That off-white, nylon gasket was used for many years on ALL Chevrolet engines. In fact, from 1956 to 1986. How well did it work? Not very well; drips were common.
        • David L.
          • July 31, 1980
          • 3310
          My 1965 Chev. Parts Catalog (May 1965) lists GM # 513975 in Gr. 1.456 for the oil pan drain bolt gasket for All models including the Corvette and describes it as "nylon - 1/2 I.D.".
          GM # 513975 was replaced with GM # 3921989 in December 1968.
          GM # 3921989 is described as "nylon 1/2 I.D. x 9/16 O.D." in my 1969 Chev. Parts Catalog.
          Dave
          • Carl N.
            • April 30, 1984
            • 592
            Plug and gasket should be painted - gasket only on part exposed may have little or no paint showing
