69 head light warning switch socket supplier? - NCRS Discussion Boards
  • Chris L.
    • November 22, 2010
    • 23
    Upon inspection, i discovered the 2 wires supposed to be connected to the socket which connects to the head light open warning switch have been ripped from the socket.
    There is no leads left to re-attach the wires to. Does anyone know any source to purchase the socket with leads? Thanks for any help on this.
    • 15632
    Re: 69 head light warning switch socket supplier?
    That connector is part of the wiring harness. AFAIK the only source will be a used Corvette from a wrecking yard. I think they prefer to be called dismantelers or something like that now days.
      • 11692
      I've found that Eagle Wire Products out of Knoxville will often sell pieces of a harness, including connectors.
      Give them a call and see if they can help.
      Else you can try Lectric Limited too.
      Patrick
        • 15632
        Patrick
        My experience is that Lectric Limited will not, but try them anyway. It has been a while since I asked and their policy may have changed.
        • Chris L.
          • November 22, 2010
          • 23
          Thanks for your feedback.
