1968-1974 4 speed transmissions..what is the advantages of the M21 versus the M22. I understand that the M21 was used with diff ratios that were in the higher range. 3:55 and higher, but what else? Is the M22 more user/driver friendly?
M21 or M22..What are the adavantages of each?
Re: M21 or M22..What are the adavantages of each?
Peter-----
The 4 gear ratios for the M-21 and M-22 were the same. The M-22 gearset is stronger than the M-21, both in terms of the helix angle of the gears and the material that the gears are manufactured from. The downside of the M-22 is that it makes quite a bit more noise and this is not desirable for street operation. Basically, the M-21 is a close ratio 4 speed designed for street operation and the M-22 is a close ratio 4 speed designed for off-road/racing applications. It's as simple as that. Can an M-21 be used for racing? Yes. Can an M-22 be used for the street? Yes.In Appreciation of John Hinckley- Top
Thanks guys for the info. Another question comes to mind after reading in another thread..Can you put a M21 high performance insides into a numbers matching stock M22 case without any detection?Peter Gregory # 4157
National Corvette Restorers Society Since 1980
- Top
Peter, Didn't you mean to reverse that question to read:Can you put a M22 high performance insides into a numbers matching stock M21 case without any detection?- Top
The actual cases are identical. NO difference except the stamping on the side. M-22 guts will be easy to ID by anyone who knows how to listen in the lower gears.Bill Clupper #618- Top
in my neighborhood) in 1st gear.
