1972 4-speed - NCRS Discussion Boards
1972 4-speed
  • D S.
    • March 1, 2005
    • 1551
    1972 4-speed
    Is there an identifying tag or some characteristic on the exterior of the 4-speed transmissions that one can immediately tell if it is an M21 or M22?
    Scott Sims
    Texas Chapter
    • 43263
    Re: 1972 4-speed
    Scott Sims
    Texas Chapter
    Scott------
    Yes, if it's a Muncie manufactured after October, 1968. There will be a suffix code after the manufacturing code of either "A", "B", or "C". "A"= M=20, "B"=M-21, and "C"= M-22. For 70-74 Muncies, a drain plug does NOT necessarily indicate an M-22.
    Of course, any suffix code only tells you what was ORIGINALLY in that case and not necessarily what's in it now.
      • 43263
      Re: 1972 4-speed
      [QUOTE=Roy Vazquez (48911);632004
      Also, I read, take a drive with a passenger, If you can have a conversation with him, you have a M21, if you can't hear him, you have a M22 (because of the whine)
      Regards
      Roy[/QUOTE]
      Roy-----
      M-22 gear noise is nowhere near loud enough to interfere with normal, in-car conversation.
      • Richard F.
        • May 31, 1986
        • 193
        Re: 1972 4-speed
        If you are always trying to get into 4th gear as soon as you can because of the gear whine, it's probably an M-22.
        • William C.
          • May 31, 1975
          • 6037
          Re: 1972 4-speed
          If original to the car, chances are about 5% it's an M-22, and the stamped ID code on the case is the Key.
          Bill Clupper #618
          • Wayne M.
            • March 1, 1980
            • 6414
            Re: 1972 4-speed
            ,..... if it's a Muncie manufactured after October, 1968. There will be a suffix code after the manufacturing code of either "A", "B", or "C". "A"= M=20, "B"=M-21, and "C"= M-22. For 70-74 Muncies, a drain plug does NOT necessarily indicate an M-22.
            Here's an example of a late 1969 Camaro from the Norwood assy. plant. Assembled two days after the letter suffixes started, on Oct 21st (P9R21x) [ x = per codes mentioned above].
