Yesterday, my 63 FI engine was getting noisy, so I adjusted the valves. The engine is stock, except for roller rockers. I set the intake to .008, the exhaust to .016. After adjustment it was very quiet, smooth, and ran very well. I then drove it about 60 miles with no problem; it performed as expected. I then stopped for dinner for about an hour.
After dinner, I got in the car and turned the key and the engine backfired through the plenum very strongly. I stopped it and examined the engine and found the number one plug wire loose and arcing to the distributor. I put it back on and started the engine. The engine ran, but had a noticeable vibration, one that was not there before the backfire. It ran poorly, for about twenty miles back home.
At home I lifted the hood with the engine running and heard a knocking from under the plenum, not unlike the noise I heard when I bent a pushrod last year. I shut it off and took the valve covers off. There was no evidence of a bent pushrod and all of the valve gaps were still in spec.
After putting it back together, it still vibrates.
Anyone got an idea of what I'm dealing with here?
