Spare tire bolt on frame bracket - NCRS Discussion Boards
  • Tom W.
    • June 30, 1992
    • 68
    Okay...figured out from replies that this is a spare tire bolt on frame bracket....now can anyone tell me where it goes? Please see attached pic...
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11334
    Re: Spare tire bolt on frame bracket
    It mounts to a tab on the rear frame crossmember using IIRC a 1/4-20 bolt, LW, PW & nut. There will be a hole in the body shaped like a donut to line it up. Remove that big bolt from it as it's not used, probably to protect the threads when blasting. The spare tire cover board uses a long bolt which passes through the cover, the spare tire, the jack, then threads into that bracket pictured. There should also be a rubber donut mounted between that bracket and the body.
    It should be shown in your AIM. Maybe the trunk section.
    EDIT.....
    It's in Section 10, Wheel & Tires.
    1957 AIM below but same thing on yours.....
