On my '54, there is a steel vaccum line that runs from the rear vacuum port on the top of the intake manifold down the left rear side of the engine, across the bottom of the engine between the rear of the oil pan and the front of the transmission, then down the right side of the transmission to its termination there. On my car, this steel line has no clips to support it anywhere and it is an obvious source of rattles as can vibrate and hit the rear of the oil pan. Should there be one or more clips to support this line? If so, what kind of clip and where does it (do they) attach? An answer to any part of the question would be helpful.
Pete
Pete
