C2 Fiberglass Repair - NCRS Discussion Boards
  • Bob P.
    • June 30, 1998
    • 143
    I'm in the process of do some fiberglass repair in an area underneath my 66 which requires laying new glass and then sanding down the area as required. I'm putting die in the resin so that the area being repaired matches the original color of the fiberglass. The issue is that when I sand the fiberglass it the repaired area and the area around it no longer matches the original fiberglass. Does anybody know how I can make these areas match the original glass?
    Bob Puls, 30633
  • Harry S.
    • July 31, 2002
    • 5330
    Re: C2 Fiberglass Repair
    After you finish sanding use straight dye on the area (like a stain) to bring back the color.
    • Donald H.
      • November 2, 2009
      • 2586
      What I did on my C1 was used a fiberglass resin color agent in the resin and patched. After I sanded I used tinted resin on a rag and rubbed the repair and sanded area around it. If it looked to shiny I rubbed with some acetone on a rag before the resin completely dried.
      Don Harris
      Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
