Help ID this timing Chain Cover - NCRS Discussion Boards
  • Doug L.
    • March 14, 2010
    • 442
    Will appreciate help identifying the timing cover shown in the attached photos.
  • Michael H.
    • January 28, 2008
    • 7477
    Re: Help ID this timing Chain Cover
    The one in the left pic is a 2nd design 64-65.
    • Doug L.
      • March 14, 2010
      • 442
      Thanks Michael. All photos are the same cover. Do you know the approximate change-over date for this cover? Can you tell me the difference between this cover and the one that preceeded it? It has been offered to me. My car is a mid-December 1963 built SHP '64 model year with 8" damper. Too early for this cover?
      Thanks-Doug
        • January 31, 1988
        Thanks-Doug[ATTACH=CONFIG]41846[/ATTACH][ATTACH=CONFIG]41847[/ATTACH][ATTACH=CONFIG]41848[/ATTACH][ATTACH=CONFIG]41849[/ATTACH]
        Doug-----
        I would say 62-68 with 8" balancer (i.e. SHP).
        • Michael H.
          • January 28, 2008
          • 7477
          Doug-----
          Joe,
          There was a unique cover used for 62 through early 64. (see previous discussion) A new design with a different timing tab was used from 64-65.
          I think the cover changed again for 66-68. I think the change was the configuration of the timing tab.
            • January 31, 1988
            Originally posted by Michael Hanson (4067)
            Joe,
            Michael-----
            Yes, I seem to recall that now as far as the 62-E64 go. Among other things, I think the welded-on tab faced upward instead of downward. I am unaware of the changes from 66-68. There very well may have been a change but I don't know what it is. Functionally, though, I think the cover pictured will work for any 62-68 with 8" balancer.
            • Michael H.
              • January 28, 2008
              • 7477
              Michael-----
              Joe,
              I'm not near my old parts books now but I remember a few (parts of) the part numbers. I think the 62-E64 cover was one number different than the damper, somewhere around 381717X.
              I don't remember the 64L-65 number but it's probably somewhere around 384xxxx.
              There was another new part/number for 66-68 and it was in the range of 3880xxx which would tell me that this part was intro for the 66 model year.
              I think the new cover timing tab for 66-68 was longer and included the "R" and one or two additional marks on the retard side of the plate.
              Hopefully, folks with original early production 365-375 HP 64 cars can help nail down the point of change from 1st design to 2nd design cover/tab.
              • Don H.
                Moderator
                • June 16, 2009
                • 2236
                my May 1 65 parts catalog shows 62-65 8" balancer as 3817173
                and the crankcase front cover for 62-65 all SHP (exc 396) as 3851549
                  • January 31, 1988
                  Joe,
                  Michael-----
                  Here they are:
                  1962-63-----GM #3817174
                  1964-65-----GM #3851549
                  1966-68-----GM #3885048
                  Each of the last two of the above became SERVICE for the previous covers.
                  Also, while there were only these 3 part numbers it's very possible that there were minor differences within each part number.
                  • Alan D.
                    • December 31, 2004
                    • 2027
                    62-63 w/oil seal 3817174 and 64 w/oil seal 3851549 (from Oct 1, 63 Chassis P & A Cat)
                    • David L.
                      • July 31, 1980
                      • 3310
                      Here they are: 1962-63-----GM #3817174 1964-65-----GM #3851549 1966-68-----GM #3885048
                      Joe,
                      I agree with most of your list but this is what I have found:
                      62-63 w/F.I., S.H.P.----GM # 3817174
                      64-65 W/F.I., S.H.P.----GM # 3851549
                      66-67 w/S.H.P. ---------GM # 3885048
                      68 w/S.H.P. ------------GM # 3923290
                      GM # 3923290 is listed in my 1968 Chev. Parts Catalog (Oct. 1967) only for the 68 Corvette 327 w/S.H.P.
                      From Chev. Parts History (service parts sold over the counter):
                      3817174 ----- replaced in Jan. 1964 by 3851549 ----- replaced in May 1966 by 3885048 ----- replaced in Jan. 1968 by 3923290 ----- replaced in 1977+/- by 361925 (disc. April 1985).
                      Enclosed is a page from one of my note books. I believe that the tab on the 66-67 and 68 timing covers for the 8" balancer probably use the large tab.
                      Dave
                      • Michael H.
                        • January 28, 2008
                        • 7477
                        • David L.
                          • July 31, 1980
                          • 3310
                          Corrected: The space between timing marks is 2 degrees.
                          I don't have a timing cover from an original 1966-1967 w/8" balancer but I do have a timing cover from a 1966 w/6" balancer as shown in the 2 photos below. The timing cover tab is marked from -16 degrees to +16 degrees and the fold is up. The measured distance from -10 degrees to +10 degrees (10 timing spaces) is about 1.08" or about 0.108" per timing space at a radius of about 3 1/8" (tab to center of C/S hole).
                          I assume the tab on a 1966-1967 Timing cover w/8" balancer would be similar in shape but the distance between degree marks would be approximately 4.125"/3.125" X 0.108" = 0.143" per timing space. The measurement between the -10 degrees to the +10 degrees (10 timing spaces) would be approximately 10 X 0.143 = 1.43" or about 1 7/16". The tab would be approximately 4 1/8" from the center of the C/S hole and the fold would be down.
                          Someone must have a photo of a 1966-1967 timing cover w/8" balancer to verify my assumptions.
                          BTW, I have noticed that the 1967 timing covers are date coded on the front face at the center. I once had one that was stamped "1" and "67" (week #1 of 1967, I believe).
                          Dave
                          • Michael H.
                            • January 28, 2008
                            • 7477
                            Originally posted by David Liukkonen (3775)
                            I do have a timing cover from a 1966 w/6" balancer as shown in the 2 photos below. The timing cover tab is marked from -8 degrees to +8 degrees and the fold is up. The measured distance from -5 degrees to +5 degrees is about 1.08" or about 0.108" per degree at a radius of about 3 1/8" (tab to center of C/S hole).
                            Dave
                            • David L.
                              • July 31, 1980
                              • 3310
                              You are correct. Each mark is 2 degrees. I will correct my mistake in my previous post so as not to confuse anyone.
                              Dave
