68 windshield wiper motor - NCRS Discussion Boards
  • Harry S.
    • May 22, 2011
    • 23
    I just installed an aftermarket wiper motor and when I tried to run it the wiper blades only went up about 1/4th of the way up and back. I checked all of the wiring and it seemed OK. When I checked the linkage movement I noticed that the motor drive shaft was ocillating but not rotating. It seems to me that the shaft needs to be rotating to get full travel of the wiper blades. Is that correct and is this possibly the wrong motor for the 68?
    • 3418
    Re: 68 windshield wiper motor
    Hi Harry,
    I believe you're right that the shaft turns 360 degrees.
    Here's a link to a video that MAY give you some help on your 68 wiper motor.
    It's from Willcox Corvettes.
    Good Luck!
      • 6956
      Harry, sounds like the wiper motor is cycling in and out of the park position. this generally means the park switch is faultly.
      • Harry S.
        • May 22, 2011
        • 23
        The video was perfect. answered my question. thank you.
        • Harry S.
          • May 22, 2011
          • 23
          You are right it was cycling in and out of the park position. The video from Wilcox clears up the question of how it should operate. thank you.
            • 3418
            Hi Harry,
            I'm glad it helped you.
            Willcox has done, and is still creating, some very helpful videos for trouble shooting things like the gauges, and the 68-72 headlight/wiper vacuum systems!
            • Tom D.
              • September 30, 1981
              • 2145
              I have one I thought was for 1968, but now I don't know for sure. Wiper Motor Assembly number is 5044626 (possibly 5044628)...
              https://MichiganNCRS.org
              Michigan Chapter
              Tom Dingman
              • Tom D.
                • 2145
                One source says 1966 Impala, plus some other "BOC" applications.
                Michigan Chapter
                Tom Dingman
