63 327/300 temperature switch - NCRS Discussion Boards
  • Kerry A.
    • August 31, 2004
    • 152
    I am in the process of installing a new thermostat and while doing so I removed the temperature switch to clean and inspect. I'm ready to reinstall and I checked my shop manual and AIM for torque specs but I'm unable to locate. Is there a torque spec and if so what is it and where can I locate it for future reference?
    • 6942
    Re: 63 327/300 temperature switch
    Kerry, The temp. switch is a pipe thread and I don't recall any torque spec.s for it. My advice is to use a wrench and tighten by hand. the 327/300 should have a case iron manifold so once it bottoms in the hole maybe give it another 1/4 to 1/2 turn.
      • 15667
      I don't think there are torque specs for NPT - just tighten until there are no leaks. Put a thin film of pipe dope on it and maybe -10 lb-ft. If it doesn't leak, you're done.
      • Tom D.
        • September 30, 1981
        • 2133
        Find "AC" or "AC Spark" wording somewhere on that sensor?
        https://MichiganNCRS.org
        Michigan Chapter
        Tom Dingman
        • Michael H.
          • January 29, 2008
          • 7477
          Kerry,
          The correct torque spec for the temp sender is 15-20 ft lbs. I would go with no more than 15, and possibly a bit less.
          The info is shown in the 1963 shop manual.
