red line tires - NCRS Discussion Boards
red line tires
+ More Options
Posts
  • George T.
    • August 31, 1997
    • 9
    red line tires
    1967 convertible, i have had red lines on for about five years now. how do you clean the red line? I have tried simple green with not much luck. I was told to use a fine sanding sponge. What do you use? thanks george
  • William L.
    • December 1, 1988
    • 944
    Re: red line tires
    I use some stuff call "Rub-O-Matic" rubber cleaner MFG ed my Tech. Its what you use to clean tire or tube before you put on a patch.
    I squirt some on a shop towel rapped around my finger and clean the stripe only. Also works great to clean white letters on a tire.
    Bill Lacy
    1998 Indy Pacecar
    • Paul H.
      • September 30, 2000
      • 688
      Re: red line tires
      I use "Bleche White" and a soapy Brillo pad and lots of water. Then I treat it with 303 Aerospace protectant.
      • Kenneth B.
        • August 31, 1984
        • 2091
        Re: red line tires
        Just use a tire cleaner & and a tire shine product to shine it.
