59 290 hp fi heads - NCRS Discussion Boards
59 290 hp fi heads
  • Al R.
    • June 30, 1988
    • 687
    59 290 hp fi heads
    My 59 290 FI engine has the 550 heads. Serial # is 43--. Any one else has these heads in this serial # range?
  • Al R.
    • June 30, 1988
    • 687
    Re: 59 290 hp fi heads
    Any 59FI owners out there?
    • Ian G.
      • September 3, 2007
      • 1114
      right here, but i won't be much help since i had to get my correct heads from somewhere else. the block was original, but not the heads...
      • Jerry C.
        • October 31, 1995
        • 741
        You did not mention the casting dates but if they are before you car was built you should be OK.
        • Al R.
          • June 30, 1988
          • 687
          Jerry, the casting dates are both A29. I'm just interested when the change over started and to see who had 550 heads in relation to serial #s, etc
