'67 seat belt retractor boot/cover - NCRS Discussion Boards
  • Neal K.
    • October 31, 2007
    • 304
    I would appreciate the posting of some pictures of the front, back and sides of the seat belt retractor boot cover for an early '67. I have been told that there are several different styles. Some short, some long, some with a hole in the back and some without a hole in the back.
    When I had my seat belts restored by Snake Oyl 2 years ago I sent my original boots to them with my seat belts. I didn't pay close attention to what the boots looked like becaiuse they were very beat up and I requested that they provide me with new ones. When I got the seat belts back they had new retractor boots but my old boots were not returned. I didn't care much since they were in such bad shape. Now that I am installing the seat belts in the car I am much wiser and have learned that you don't always get exactly what you ask for. The new boots Snake Oyl provided are short but have a hole in the back which I think may not be correct for an early 67. Any assisstance would be appreciated.
    Neal
  • Peter L.
    • May 31, 1983
    • 1930
    Re: '67 seat belt retractor boot/cover
    Neal - The seat belt retractor covers on our Sept 66 built 67 (VIN 1476) with saddle seat belts dated 35 E 66 are relatively short and have a smooth back with no hole for the large rivet head. I will try and get you some photos. Pete
    • Neal K.
      • October 31, 2007
      • 304
      Pete,
      That is what I thought it would look like. Pictures would be most appreciated.
      To my knowledge none of the repops from the ususal supply sources are correct. But someone may have had different results. Any ideas where I might locate corrrect ones?
      Best regards
      Neal
      • Donald S.
        • August 31, 1996
        • 186
        Neal,
        Seat retractor covers from our Sept 66 built 67 (1513). I hope it helps.
        Don
        • Jaime G.
          • April 1, 1988
          • 480
          The seatbelt retractors from my Dec 29 coupe are identical to the one posted by Donald Smith except black in color
          with no hole . Hope that helps
          • Neal K.
            • October 31, 2007
            • 304
            Don, Thanks for the photo.
            Jaime, Thanks for the cooberation.
            Anyone have a lead on where to find correct boots?
            Neal
            • Russ S.
              • April 30, 1982
              • 2162
              Originally posted by Neal Kalis (48092)
              Pete,
              Best regards
              Neal
              Try Charlie Santorelli (Spelling) seat belt city in New Jersey
              • Neal K.
                • October 31, 2007
                • 304
                Russ,
                Thanks for the suggestion.
                I know Charlie, he restored my vent window assemblies and did a great job.
                Neal
                • Gary B.
                  • February 1, 1997
                  • 7024
                  Neal,
                  I believe that the seat belt pocket for early '67 cars is the same as for late '66 cars. And based on my research there is no repro that is accurate. Used originals are your only option.
                  Gary
                  • Neal K.
                    • October 31, 2007
                    • 304
                    Gary,
                    I believe you are correct.
                    Any suggestions on who I can contact for used ones.
                    Neal
                    • Gary B.
                      • February 1, 1997
                      • 7024
                      Neal,
                      I don't know who to contact, but if you find out please let me know as I need two good black ones for my July build '66.
                      Gary
                      • Scott S.
                        • September 11, 2009
                        • 1961
                        Neal,
                        My Jan. '67 seat belt retractor covers look the same as Don's in post #4, except black.
                        One of mine was damaged, part of the boot had broken or torn away. When I had my belts cleaned and buckles restored, they replaced the covers (I also had my original covers returned). The replacements look the same as the originals on the the upper section that is visible when installed, with a raised dome (no hole) as shown in Don's picture. The lower section was a little different. The originals have no slot cut into the lower section, while the replacements do have a slot, and the end of the seat belt assembly that attaches to the body (the metal yellow-cad plated bar) is inserted through the slot in the lower/rear part of the seat belt cover.
                        • Gary B.
                          • February 1, 1997
                          • 7024
                          Scott,
                          The slot on repros and on NOS GM boots/covers is an obvious difference from production originals.
                          Gary
