'72 fuel tank Vapor Check valve - NCRS Discussion Boards
  • Tom L.
    • October 17, 2006
    • 1439
    Went for a run last night and filled up. After stopping we smelled gas. Turns out that the check valve on the drivers side of the tank that leads to the charcoal canister is leaking. I took it out and got a couple of pieces of hose, put it in water and blew. I quikly found the leak. It was on the seem on the bottom. Has anyone had any had any luck re-sealing these valves???
    I do not relish the idea of fuel dripping on the muffler, fire is bad! Thanks!!
  • Christopher K.
    • September 10, 2007
    • 311
    Re: '72 fuel tank Vapor Check valve
    Lynn
    Same thing happened to me on my '73. I haven't seen anyone fix these. I have seen some Nos ones for sale and most vendors have a repro for around $45. And yes, it is a dangerous area to leak!
    Good luck,
    Chris
    '72 Lt-1 a/c Pewter Silver coupe Mason Dixon Chapter Top Flight 2016
    '73 L82 4 spd Dark Metallic Blue coupe Chapter Top Flight 2023
    • Gerard Q.
      • February 1, 2000
      • 284
      GT-380.JPGZip has them
      http://www.zip-corvette.com/ProductD...=SGR-SR&CTitle=&
      • Don L.
        • August 31, 2005
        • 1005
        FWIW, I used some epoxy to seal a crack on one of these one time. I did this approx 2 days before I ordered a new one.
        It still leaked and like you, Lynn, I didn't like thinking about the consequences. I did replace it without having to drop the tank. Not easy, but after the bleeding stopped and cuts healed, I was happy with the outcome.
        Don Lowe
        NCRS #44382
        Carolinas Chapter
        • Tom L.
          • October 17, 2006
          • 1439
          Several years ago I removed it because the hoses rotted but the valve was OK so I have experience changing it without dropping the tank. I have the painful memories made by all those sharp edges.
          I was hoping there would be some kind of epoxy that might resist gasoline, I know most don't. I really want to use the car this weekend, there's a show I'd like to attend. Guess I'm waiting for UPS to get here. Thanks anyway!!
          • Mike F.
            • April 25, 2011
            • 668
            JB Weld might work. I fixed a hole in a rental cars transmission that way, but thats a whole other story.
            • Don L.
              • August 31, 2005
              • 1005
              Dude, ya can't just stop there! C'mon...
              Don Lowe
              NCRS #44382
              Carolinas Chapter
                • 43258
                Lynn-----
                The type of plastic used for the separator is extremely difficult to repair. I believe it's linear polypropylene or some similar plastic. No epoxy is going to bond to it. Most epoxies are extremely resistant to gasoline but that's not the problem here; the problem is getting the adhesive to bond to the plastic. I've been told that Permatex/Locktite now has an adhesive that will bond to this type of plastic. However, whether that adhesive is resistant to gasoline I do not know.
                The best plan: obtain a NEW separator.
                • Paul B.
                  • April 30, 1995
                  • 482
                  ...I repaired the one on my '74 L-48 coupe 7yrs ago with JB Weld and it's been perfect since.
                  • Tom L.
                    • October 17, 2006
                    • 1439
                    Did you do anything specific to prep the surface before applying the epoxy??
                    • Mike F.
                      • April 25, 2011
                      • 668
