mid year big block running hot - NCRS Discussion Boards
    • 43250
    #31
    Re: mid year big block running hot
    But as you go into the seventies you find that centrifugal curves were shortened and initial timing was less than antecedant pre-emission engines. Vacuum advance was often more, but only at very high manifold vacuums.
    The '74 Califronia L-48 automatic, which probably represents the worst of the lot, is speced at 4 deg. initial and has nominally 18 degrees full centrifugal at 4200, so at WOT high revs total advance was only 22 degrees vs. the optimum of 38. That took a huge hit on peak power!
    I don't think it had to been this way as WOT, high revs was never a part of the emission certfication procedure, but as Dave McClellan said in his book, sometimes they were up against the wall to get an engine/drivetrain configuration certfied in time to have a product that could be sold on announcement day, so the goal was to get the car certified whatever the cost in power.
    Duke-----
    The 70-74 models with CCS were unquestionably the worst. That's why I prefer AIR to CCS. However, some of the 72-74 may have had elements of CCS combined with AIR.
    • Glen C.
      • November 1, 1985
      • 193
      #32
      Here's what fixed my L72 over heating problem. A properly calibrated gage sending unit. It took three to find a good one. New Dewitt aluminun "Direct Fit" radiator & new reproduction fan shroud. Changed the ported vacuum to full time, (Thank you Duke) & changed the vacuum can to a VC1765 aka B26. Here's a bonus, hook up a "puke" bottle next to the radiator. Gage never goes over 180* and I'm in Florida.
      • Michael J.
        • January 27, 2009
        • 7146
        #33
        The puke bottle is especially handy to save your garage floor after a long cruise in hot weather......
