1974 454, what kind of pistons does it have, flat, dished or domed? How can I raise the compression to 9.75?
Pistons/ increasing Compression ratio
Re: Pistons/ increasing Compression ratio
What is the casting number of your cyl heads?Bill Clupper #618- Top
Original pistons were flat top with 2 "eyebrow" style valve reliefs.
Assuming that you have stock 113 cc heads, installing Keith Black pistons KB201 or KB203 will give you close to the compression ratio you seek.In Appreciation of John Hinckley- Top
