Transistorized igintion 427/390
Re: Transistorized igintion 427/390
I guess...I was looking for a hotter spark.
Bob
9944- Top
With a distributor machine, any 62-74 Corvette distributor can be set up to the original specifications of the particular application desired. The notion that one has to obtain an NOS distributor (presumably one of the original part number) or you can never achieve what needs to be achieved is, thus, absurd.In Appreciation of John Hinckley- Top
These units will not provide any additional spark energy- nor will any other conventional ignition system. A coil discharges as soon as it has enough electrical energy stored to ionize the air gap of the plug which typically takes around 9,000 volts or so. Installing a super zoomy blaster coil with an advertised rating of 40,000 volts (and the flashy graphics to go with it) makes no difference as the plug still fires as soon as the coil has stored 9,000 volts. The stock coil has more than enough capacity to do the job, and more.
The pertronix units or similar are simply an electronic switch which the replaces the points- which are a mechanical switch. They cannot and do not affect the coil output in any sense.- Top
I'll bet that the group of distributors that can be made to work is a lot larger than '62-'74 Corvette. I would suspect any Chevrolet V8 points distributor would work. I agree with the others here; get a new mechanic!- Top
Find one who owns an old-fashoned distributor machine, and with a little creativity the operator will get you any curve you want within reason.Bill Clupper #618- Top
Yes, just about any Chevrolet V-8 distributor could be set up to the original specs of the distributor for any application. However, unless a 62-74 Corvette distributor was used, the tach drive function would be lost.In Appreciation of John Hinckley- Top
if you want a better ignition and still keep your points build one of these dwell extenders. it electronically closes the points as soon as they open increasing the dwell time.Attached Files- Top
That said, I AM looking
Bob
9944- Top
- Top
Bob -
None of the drop-in conversions (Pertronix, Breakerless SE, etc.) are "electronic ignition systems"; they simply replace the electro-mechanical switch (the points) with an electronic switch module that does exactly the same thing, and they don't increase the "spark energy" at all. They also aren't sold in retail auto parts stores, so unless you carry a spare module (or a set of points and condenser), if they fail, you're dead on the side of the road. They DO spare you the gruesome chore of setting dwell once a year and changing the points once every five years.
thanks,
Bob
9944- Top
Bob
9944- Top
- Top
Bob,
Not being cute, but I've tried to help in every single thread you've posted.
If you post a comment that doesn't make sense I think it's reasonable to ask for clarification.
At this point I'd ignore/throw away/forget everything you were told by your former mechanic.
Wait for your new one to work with you and go from there. I don't think it's worth your time to "what if" based on bad information.
Patrick
Bob
9944- Top
