1960 rear axle identification - NCRS Discussion Boards
  • Tom W.
    • June 30, 1992
    • 68
    The rear axle on the 1960 corvette has the following cast # gb208 and below it # 3725899. I have looked up the info in corvette by the numbers book and page 437, the cast # 3725899 is located...what does the gb208 mean?
  • Gary C.
    Administrator
    • October 1, 1982
    • 17657
    Re: 1960 rear axle identification
    Tom,
    Driver's side cast number would be the part # 3725899, which is the standard rear end part number. The other four (4) should be digits representing the month and day such as 01 29; 01 for Jan and 29 for 29th day.
    Passenger side stamped in is the gear ratio (2 alpha characters) and the assembly date.
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
      Originally posted by Tom Welsh (21179)
      The rear axle on the 1960 corvette has the following cast # gb208 ..what does the gb208 mean?
      Tom -
      Take another look at what you stated as "gb208" - do you have a photo?
      • Tom W.
        • June 30, 1992
        • 68
        It is B208 and on the other side is AM 122...only the last 2 is really visible...
          Tom -
          B208 is the casting date, February 20, 1958, and the "AM" ratio code identifies it as being a 3.36, originally installed in a 1958 passenger car with Powerglide. The "AM" ratio code wasn't used in Corvettes, but the axle center section was shared with '55-'64 passenger cars, and many were swapped. If what appears to be "AM" is really "AN", it could be a Corvette 3.70 center section, used with manual transmissions.
