1970 LT1 Fan Shroud Extension - NCRS Discussion Boards
  • David S.
    • August 9, 2009
    • 595
    Can someone post a picture or describe what an original 70 LT1 fan shroud extension should look like. Is it a half circle or full circle? How wide? etc.
    Dave
    • 43219
    Re: 1970 LT1 Fan Shroud Extension
    Dave
    Dave------
    It's "half-round" and ABOUT 4" wide. It's basically the same as the 69-72 big block extension except it's wider. I have one around here but I can't get at it right now.
    • Kenneth B.
      • August 31, 1984
      • 2087
      Dave------
      I beleave that is what mine are but I can't look because they are on the way to AZ. I did look at my 70/454 & they look about the same but like you said I think the LT-1'S are deeper.
      • Dave S.
        • August 31, 1992
        • 2924
        Dave
        David,
        I only have a top photo of VIN #14803
          • 15599
          The chances of getting a photo of that puppy with the car together from the top are slim to none. You might be able to do it with the car on a lift, but that is the only chance. I seem to remember a drawing in the AIM on the page that shows the LT1 fan shroud, but then maybe I am hallucinating again.
            • 11643
            This one borrowed from Corvette Central is essentially correct:
            • Paul O.
              • August 31, 1990
              • 1716
              That is what I was going to say it also had a rectangular notch in it but Patrick's picture post is worth a thousand words.
              • David S.
                • August 9, 2009
                • 595
                Thanks guys. Now I'll need to start searching for one.
                Dave
