Door certification label - NCRS Discussion Boards
  • Reba W.
    • 938
    What year did the certification label on the driver's door change from blue to white?
  • Michael W.
    • April 1, 1997
    • 4290
    Re: Door certification label
    I believe the white ones appeared late in '75 model year production.
    • Anthony S.
      • April 30, 1998
      • 156
      When did the Blue lables start to appear?
        • 15640
        At the time that 1970 production began for most Chevrolet models (Corvette and Camaro excepted). So it began in late August of 1969 for Corvette. I am not sure what the TIM&JG says, but I have a M29 = Friday August 29 Corvette with a blue Cert label. It could have began somewhat earlier, but not much. These early labels are different than later ones.
        • Reba W.
          • 938
          The TIM&JG lists September 1, 1969, as the starting date, and that was not changed in the latest revision.
            • 15640
            W3ell that is a revision I missed, but then it is only a few days. Oh well I wouldn't expect it to create an issue anyway.
              The certification label Federal requirement became effective September 1, 1969; photo below shows the first version on a '69 Camaro. Two ribs for locating it showed up in the doors starting in late July, and both plants began applying the labels in late August.
                • 15640
                Norwood John?
                  Norwood John?
                  The label in the photo is on a Norwood car ("N" in the VIN). Van Nuys started cert labels at the same time (on Camaro and Impala/Caprice).
