Can someone help identify where these go? - NCRS Discussion Boards
  • George W.
    • November 1, 1993
    • 68
    I am pretty sure I removed these from my 73 coupe, while taking it apart many years ago. For some reason the doors come to mind, but I'm not sure where they would fit. The car does have power windows. They are made from a heavy dense form. Any help would be appreciated.
    George Walker
    • 3418
    Re: Can someone help identify where these go?
    Hi George,
    Those fillers are located in the rear clip right behind the fiberglass halo and birdcage.
    In my 71 AIM they're shown on UPC 1, Sheet B 9.
    Here's 2 pictures. The interior rear quarter trim helps hold them in place.
    • George W.
      • November 1, 1993
      • 68
      Thanks Alan for you response. After your post I went back to the 73 AIM and found where the part was located. I found it odd that in the 73 AIM, this pad was indicated on a UPC sheet that describes body panel bonding. I will say, that 10 years ago, if I had known how bad my memory would be today, I would have taken better notes!
