Tire Rotation Strategies - NCRS Discussion Boards
  • David B.
    • July 7, 2011
    • 88
    I'm curious about how you guys rotate your C1's radial tires. Some questions:
    - Do you merely swap front and back staying on the same side, without crossing over (e.g., right rear to left front)?
    - Do your rotate a spare into the mix? If so, what's your pattern?
    - Is the C1 owner's manual rotation pattern (which includes a spare) for bias ply only?
    - Any special insights for minimizing wear?
    Thanks!
    Dave
    • 6956
    Re: Tire Rotation Strategies
    Dave, Generally its front to back keeping tires on the same side. The only reason other wise is if your experiencing a radial tire pull. you can rotate them in the X pattern.
