E1956 dipstick - NCRS Discussion Boards
E1956 dipstick
  • Joseph P.
    • February 26, 2008
    • 26
    E1956 dipstick
    I have an E1956 and looking for a picture of this dipstick. The GM #372260. Or better still the dipstick. Can anyone help?
    Thanks, Joe (48633)
  • David L.
    • July 31, 1980
    • 3310
    Re: E1956 dipstick
    Joe,
    According to my notes the 1956 Chevrolet Parts Catalog lists the 1956 Corvette dipstick as GM # 3728130 and is described as "19 9/32 under washer". I sold the 1956 catalog several years ago so I can not double check the part number.
    My 1957 Chevrolet Parts Catalog (March 1957) lists the 1956 Corvette dipstick (1st design) as GM # 3722960 and is described as "19 13/32 under washer". My 1963 Chevrolet Parts Catalog (Oct. 1962) describes the 3722960 as "single piece" and A = 17 37/64" and B = 18 27/64".
    I assume you know the meaning of the A & B dimensions.
    I assume GM # 3728130 was replaced with GM # 3722960. The Parts History section index in my 1963 catalog only goes back to 1960. My 1957 catalog does not have a Parts History section.
    The 1956-1957 Corvette dipstick (2nd design) is GM # 3722959 and is described as "21 9/16 under washer" according to my 1957 catalog.
    My 1963 catalog describes the 3722959 as "single piece" and A = 19 31/64" and B = 20 7/16".
    The 3722959 dipsticks sold over the counter in the 1980's was a two piece dipstick riveted together very similar to the 1958-1963 Corvette & Chev. Truck dipstick (GM # 3739830).
    The oldest dipstick that I currently have in my "collection" is an original 1958 Chev. Pass. dipstick (GM # 3747979, single piece, A = 18 35/64 and B = 19 5/16). The length "under washer" measures about 20 5/8".
    Dave
    • Joseph P.
      • February 26, 2008
      • 26
      Re: E1956 dipstick
      Hi Dave,
      Thanks for your reply. I had both numbers 3728130 and 3722960 and the dimensions, can you tell me is the 3722959 looks like the 1st design dipstick, ie. two piece riveted together and the embossment ( full and add ) are the same and does the letter B or M show just above the felt?
      Thanks, Joe
      • John S.
        • July 29, 2009
        • 640
        Re: E1956 dipstick
        [QUOTE=David Liukkonen (3775);628313]Joe,
        the 56 part book list the 1st design as 3722960, 19 13/32 under washer. the number 3728130 does show up in the back of the 56 parts book being replaced by 3722960 on 10-1-56.
        • David L.
          • July 31, 1980
          • 3310
          Re: E1956 dipstick
          Originally posted by Joseph Pennacchio (48633)
          Hi Dave, Thanks for your reply. I had both numbers 3728130 and 3722960 and the dimensions, can you tell me is the 3722959 looks like the 1st design dipstick, ie. two piece riveted together and the embossment ( full and add ) are the same and does the letter B or M show just above the felt? Thanks, Joe
          Joe,
          I once owned an original one-piece dipstick that I removed from a 1957 Chevrolet, GM # 3722959 as per My 1957 parts catalog.
          I also bought a new 3722959 dipstick from my local Chevrolet dealer in the early 1980's and it was a two-piece dipstick with a 3" long handle and a spacing between the "ADD" and "FULL" marks that measured about 1 1/32" as best as I could measure. According to my notes "A" measured about 19 9/16" and "B" measured about 20 19/32". I sold both dipsticks to someone a couple of years ago.
          I have never seen a 3728130 dipstick or a 3722960 but according to the parts catalogs they are one-piece dipsticks. I would assume that they were the same as the original L1956-1957 Chevrolet & Corvette (2nd Design) one-piece dipstick, GM # 3722959 except for the length and the "A" and "B" dimensions.
          The 1958-1963 Corvette & Truck dipstick (GM # 3739830) is a two-piece dipstick. I have had several of these over the years with the earliest one from a 1959 Chev. Truck (Eng. stamped "F721M" with a "G209" casting date or July 20, 1959).
          For what it's worth enclosed are 3 photos of my 1958 Chevrolet 283 dipstick ("A" measures about 18 17/32", book is 18 35/64" and "B" measures about 19 5/16", book is 19 5/16"). Note the encircled letter "E" right after the word "FULL". I have other dipsticks with the letters "E", "B", and "M" which I assume are the manufacturers.
          Dave
          • Mike M.
            • May 31, 1974
            • 8409
            Re: E1956 dipstick
            my 56 dipstick, out of its original engine(vet is vin 1566) is a one piece dipstick, stamped Add with arrow pointing to a stamped line, and Full with arrow to another line. all info is stamped, not embossed. the distance from underside of the washer to the tip of the dipstick is 19 3/8". i believe it is original to this first design oil pan. mike
            • David L.
              • July 31, 1980
              • 3310
              Re: E1956 dipstick
              Mike,
              Does the "A" dimension measure 17 37/64" and the "B" dimension measure 18 27/64" or something reasonably close like 17 9/16" and 18 7/16"?
              Dave
              • Mike M.
                • May 31, 1974
                • 8409
                Re: E1956 dipstick
                can you post a drawing of a dipstick and define A and B ? my dipstick isn't stamped like yours--there are arrows pointing to the transverse stamped lines. don't know how to post pics on tdb. mike
                • David L.
                  • July 31, 1980
                  • 3310
                  Re: E1956 dipstick
                  Mike,
                  The link below explains the "A" and "B" dimensions of a dipstick.
                  Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.
                  Does your E1956 dipstick stamping look like the photo below?
                  "ADD" over "OIL" (small letters w/arrow)
                  "FULL (large letters w/arrow)
                  Dave
                  • Joseph P.
                    • February 26, 2008
                    • 26
                    Re: E1956 dipstick
                    Thanks Mike,
                    I have #284 and just found an original oil pan. I have never seen an original dipstick so I cann't say weather it is a one or two piece. The book calls for the distance from the washer to the tip is 19 13/32 (3/8). If I give you my address will you send me pictures of your dipstick?
                    Thanks, Joe
                    • Joseph P.
                      • February 26, 2008
                      • 26
                      Re: E1956 dipstick
                      Thanks Dave,
                      It sounds like it could be a one piece dipstick. The only people that can say is one who has E1956.
                      Thanks, Joe
                      • Mike M.
                        • May 31, 1974
                        • 8409
                        Re: E1956 dipstick
                        A = 17 1/2" and B = 18 5/8" mike
