The oil leak continues...............................63 L84 - NCRS Discussion Boards
  • Tim S.
    • May 31, 1990
    • 713
    I am still fighting an oil filter leak on my 63 L84. Here is what has been done to this point.
    Reproduction canister changed to an original. That fixed the leak from the center bolt
    Reproduction bypass valve.
    Checked the seal surface in the block. All looks good.
    Oil pressure 60 lbs cold, 35 warm
    I have changed the filter and gasket a few times figuring I screwed something up.
    This is an engine that is fresh and I have no prior experience with this engine (came with car already rebuilt) I am no stranger to canister style filters but have never struggled like this before.
    Is there something I am overlooking?
    Tim
  • Michael G.
    • January 1, 1997
    • 1251
    Re: The oil leak continues...............................63 L84
    Tim
    • Did you verify these is not the remains of the old canister gasket stuck to the block?
    • Torque to spec? Over torqued?
    • Mis-aligned gasket.
    Repro canisters are notorious for being unreliable. I've been restoring original canisters for years......typcially no issues involving a canister leak where it mates to the block.
      • 43258
      Michael-----
      I expect the reason is the cost of the tooling to manufacture a canister like the originals. Aren't the reproductions also a bit thinner material than the originals (another compromise necessitated by the cost of the tooling)?
      • Michael G.
        • January 1, 1997
        • 1251
        Michael-----
        Joe,
        From what I've seen repro canisters are one gauge thinner than original. Unfortunately unsuspecting buyers are unware of this. Hard to beat an original canisters fittment.
        • Tim S.
          • May 31, 1990
          • 713
          I have taken another stab at it. This time, torqued to 20 lbs. Much better, but still leaks a some. BTW the old gasket is out of there. I am a little puzzled, how can the gasket get misaligned given it is captured between the bypass and the block casting?
          And yes, the reproduction canister is noticably thinner than the original.
          Tim
          • Michael G.
            • January 1, 1997
            • 1251
            Tim
            If you have a service manual might check the torque spec as mentioned above. Believe it may be more than 20 lb.
            • Kenneth B.
              • August 31, 1984
              • 2091
              Michael-----
              Yes the repos are thinner than the originals. Much easier to form than the thicker ones. Make sure the bolt is tight centered.
                • 43258
                Michael and Tim------
                Spec is 25 lb/ft.
                • Cecil L.
                  • May 31, 1980
                  • 449
                  Make sure the bell housing bolt isn't too long. It can protrude into the area and damage or deform the seal.
                  • Tim S.
                    • May 31, 1990
                    • 713
                    You were spot on Cecil! After utilizing an original canister, installing a seal kit, 25 lbs of torque, and changing the bellhousing bolt, all is good. The TDB proves you never do know it all. I cannot believe I made it all of these years without a problem before.
                    Thanks to all who contributed.
                    Tim
                    • Jerry G.
                      • April 1, 1985
                      • 1022
                      Also be sure your venting system is installed and functioning properly. i know from experience that small blocks build up internal pressure that caused all sorts of little leaks. Jerry
                      • Ken A.
                        • July 31, 1986
                        • 929
                        Are you using grease on the gasket? Do not install it dry.
                        • Tim S.
                          • May 31, 1990
                          • 713
                          Yes I is
