54 body mount coushions - NCRS Discussion Boards
  • Guy M.
    • November 1, 1993
    • 500
    I can locate 7 coushions, 3 on each side and 1 on the very rear. Is there an 8th or is that it? I have 8 in the package. The front seems to be taken care of with the radiator coushion. Thanks as always folks. Also Im electing to install a ball valve at the fuel line junction for future fuel pump replacement. I know its not an original setup but easily removed if judging ever happens.
  • Chris S.
    • January 1, 2000
    • 1068
    Re: 54 body mount coushions
    there are four on each side.
    four across the firewall - toe board
    two in back of the seats
    two in the rear - corner of the crossmember
    The tire hold down in the center is not a body mount
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Tim E.
      • April 1, 1993
      • 360
      Guy - I think Chris gave you the answer you need but I'm wondering which cushions you're referring to since I have 4 distinctly different types of rubber cushions on my '54!
      See the frame diagram below: I have one rubber disk at the rear spare tire mount bracket (type 1). I have 5 rectangular ribbed rubber cushions marked "cushion" on the diagram and glued directly to the frame (type 2). At body mount points 2-9 (all 8 locations), I have a rectangular rubber cushion glued to the inside above the fiberglass floor and a loose one below the fiberglass floor but above the steel shims in each stack (type 3). At the rear cross member points 10 & 11, I have a thick rubber cushion above and another below the fiberglass trunk floor (but above the steel shims) in each stack (type 4).
      If you have 8 in the package, they're rectangular, and about 1/8" thick, I would assume these are the 8 that fit in the shim stack below the fiberglass floor but above the steel shims at points 2-9. The others must be sold separately!
      Tim
      54CorvetteBodyCushions.pdf
      • Chris S.
        • January 1, 2000
        • 1068
        The rear one in the middle of the spare tire well is a seal type - it is not a body mount- it seals the hole where the trunk board hold down bolt comes thru (supposedly)
        I correct myself - there are 11 body to frame mounts -
        4 in the front along the toe board
        4 behind the seats
        2 at the rear frame corners
        1 at the front core support - different kit
        then there are rubber "cushion" - they are not body mounts - sit on the frame between the glass - support the glass
