Need help identifying my brake cylinders - NCRS Discussion Boards
  • Stephen R.
    • May 20, 2008
    • 302
    I have replaced all 4 of my brake cylinders and now have decided to have the old ones rebuilt. I'm not sure that they are the original cylinders to my 59 and don't want to waste the money rebuilding incorrect parts. The following are the numbers off of the parts:
    First: 1 1/8 " 5453821 (large 821)
    Delco Moraine Prod Dayton Ohio
    second:
    1 1/8" 5453822 (large 822)
    Delco Moraine prod Dayton Ohio
    third: there is an "R" upper boss left and a vertical "76" upper boss right
    1" 5456649 (large 649)
    fourth: not much identification but has: EIS 519. below that, "made in USA", below that P9.
    Any help identifying these would be appreciated.
    Steve
  • John F.
    • March 23, 2008
    • 2414
    Re: Need help identifying my brake cylinders
    My 62 has the large 649s on the rear, both sides. My fronts are 1 3/16" 5459527 & 528.
    • John F.
      • March 23, 2008
      • 2414
      Pics of the 649s.
      • John S.
        • July 29, 2009
        • 640
        649 are definitely used on the back in 59. i know earlier corvettes were using the 821 and 822 and believe they are used on the 59. the 527 and 528 with the 1 3/16 bore were used in 60 thru 62 exc HD
        • Stephen R.
          • May 20, 2008
          • 302
          got another question.
          The 821/822 are left/right cylinders. Is the 649 also left/right? Seems weird that they would use one number for two different cylinders but a guy on Ebay has a set of 649's for sale and they are different.How can you tell left from right?
          • Peter R.
            • June 19, 2011
            • 233
            No, the 649s are identical--doesn't matter which side of the car you use them on. The fronts are mirror images of each other and so there are separate left and right cylinders; therefore two different part numbers in the front, but only one part number in the back.
            Pete
            1954 Corvette #814
            1957 Corvette #646 -- FI, 3-speed
            • John S.
              • July 29, 2009
              • 640
              you better look again if you have a car. both brake lines hook up toward the rear of the car. so there is a right and left hand cylinder.
              • Peter R.
                • June 19, 2011
                • 233
                You're right, John; I stand corrected. On my '57 the rears are left and right because their ports are angled to the rear. On my '54, the rears are the same--the brake line enters through a right-angle brass block, so the ports in the rear cylinders are not angled. Sorry.
                Pete
                1954 Corvette #814
                • Stephen R.
                  • May 20, 2008
                  • 302
                  Is there a marking on the cylinder that indicates left/right or is it just a matter of fitting it up to the plate?
                  • John F.
                    • March 23, 2008
                    • 2414
                    No L or R on the 649s. Use on either side.
                    • Stephen R.
                      • May 20, 2008
                      • 302
                      Here's a picture of the 649's. Which is the passenger's side and which is the driver's?
                        • 43246
                        Peter-----
                        For the rear brake cylinders the CASTINGS are the same for each side, thus both have the same CASTING NUMBER. However, the FINISHED PART NUMBERS are different for either side since the castings are machined differently for either side. The finished part numbers are shown nowhere on the cylinders, though.
                        Delco-Moraine did the same thing with caliper halves for 65-82 Corvettes. Some of the caliper halves use the same CASTING NUMBER for both sides but each side is machined differently so, even though they have the same casting numbers, the halves are unique to a particular position.
                        • John F.
                          • March 23, 2008
                          • 2414
                          Look and see what side the brake line is coming from. If from the front use that WC, if from the rear, use that WC.
                          • Richard M.
                            Super Moderator
                            • August 31, 1988
                            • 11334
                            From the Parts Book below
                            FRONTS:
                            1953-1959, 1960-1962 w/HD Brakes,Susp
                            Front Left- 5455479 (cast 5453822 1-1/8")
                            Front Right- 5455478 (cast 5453821 1-1/8")
                            REARS:
                            1956-1962, Exc HD Brakes,Susp
                            Rear Left- 5459918
                            Rear Right- 5459917
                            • Stephen R.
                              • May 20, 2008
                              • 302
                              The problem is that I have the WC shown on the left I want to buy the one on the right but don't know what to ask for or how to describe it since they both show the same number. I'll crawl under the car tomorrow and see if I can Identify what I have.
