62 wonderbar radio parts - NCRS Discussion Boards
  • Joseph P.
    • September 7, 2009
    • 138
    I bought my 62 with an aftermarket radio installed and the original in a box. The guy I bought it from said he wanted a better sound. I had the original repaired by Jerry Rudbeck, the best there is IMO. Will spend all the time you need with you. A real gentleman. However when I went to install it to the center console I noticed I didn't have the washers and nuts necessary to hold the radio in place. Talked to Jerry but he doesn't have any and he said to be careful with knock offs because the thread is usually different. Does anyone know where I can buy them and does anyone have a schematic, I looked in Nolan's and AIM and don't see it. Thank you Joe
  • Stephen G.
    • January 1, 2002
    • 305
    Re: 62 wonderbar radio parts
    I think I've used the repro nuts and they were fine. All the vendors should have them. Any yes Jerry is the best !
    Steve Gansky
    Newtown, (Bucks County) PA
    • Terry D.
      • May 31, 1987
      • 2697
      Joseph
      Just ask the vendor before you buy if they are correct and if not can you return them. As Stephen said most vendors will have the correct ones, word would get around pretty fast if they did not work.
      • Joseph P.
        • September 7, 2009
        • 138
        Thank you for the input.
