1968 Early vs Late Build dates - NCRS Discussion Boards
  • Joe M.
    • February 18, 2010
    • 83
    I'm tryingto interpret in 1968 what build dates are early vs late. If you can please provide any information orhelp descramble build dates between (H) and (I) build dates I would appreciateit. Are the early or late builds?
    Thanks in advance
  • Jack C.
    • September 30, 1992
    • 1090
    Re: 1968 Early vs Late Build dates
    Joe. my 68 January 22 built car (#9643), from what has be discussed, is a very late early car. It happens to be one of the first coupes built as well. The rule of thumb was that the coupes were first manufactured around the 10,000 serial number.
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
    • Michael W.
      • April 1, 1997
      • 4290
      This question gets asked frequently. This might help
      https://www.forums.ncrs.org/showthre...late-breakdown
      • Joe M.
        • February 18, 2010
        • 83
        Thanksfor the help Jack, I appreciate it. What I'm trying to find out is what month (ifthe timeline even exists) did they change from early to late (in the parts run)for a 1968 L71 Coupe. Theyidentify an early block 3916321 to alate block 3935439 for the year so which ones fits when? The same for the intake on the L71 as the early is 3919852 and late is3937797. The build date I'm trying to decipheris and April date. I'm getting thefeeling I'm looking for a clear cut off date which doesn't exist.
        • Joe M.
          • February 18, 2010
          • 83
          Thanks for the help Michael, I appreciate it.
          • William C.
            • May 31, 1975
            • 6037
            As GM did not use a first in-first out inventory, and from an assembly plant viewpoint no changes were required, either could have been used at the assembly plant in your timeframe it would appear, with no certainty that either was correct or incorrect.
            Bill Clupper #618
            • Michael W.
              • April 1, 1997
              • 4290
              I think the message here is if the engine block existed, it got used in production. I'd be hard pressed to come up with an explanation of why a part with an early date could not have been used in a car built a few weeks later.
              • William C.
                • May 31, 1975
                • 6037
                GM used two kinds of changes to component level parts in production, coordinated changes requiring a change in the final ASSEMBLY part number or running changes where the new and old part were generally interchangable. Unless the AIM shows a change in the finished assembly part number for your engine, the assembly would not necessarily even know that a component level change had occurred. The engine group may have sent a notice of the change to the assy plant, but it would have been of little-no significance to the actual build process.
                Bill Clupper #618
                • Joe M.
                  • February 18, 2010
                  • 83
                  Thanks for your help Bill, I appreciate it. I guess with some of the build dates on early vs late its more of an art vs a science.
                  • Paul J.
                    • September 9, 2008
                    • 2091
                    That is correct. There might be some discussion on this in the judging manual, but I don't know for sure.
                      • 3416
                      Hi Joe,
                      I think you can take comfort in knowing that cars often? have a few parts that seem a bit out of the time frame you might expect. (But with-in the 6 month period for most parts.)
                      My 71 base sb with a cylinder case cast on Dec. 31, 1970, and assembly date of Jan. 7, 1971 has an intake manifold dated August 1970. That's really the oddest date I've seen on my car. Next closest to odd would be the birdcage date stamp of September 1970. But since I don't know if that date is when that particular part of the birdcage was made, or if it's when the birdcage was assembled, or if it was stamped at another time, I've just been amused at even seeing it.
                      • Joe M.
                        • February 18, 2010
                        • 83
                        If I could ask anotherquestion. Does this tri power air cleaner lid look original to you? Thanks for the help, I appreciate it.
                        • Paul J.
                          • September 9, 2008
                          • 2091
                          If I could ask anotherquestion. Does this tri power air cleaner lid look original to you? Thanks for the help, I appreciate it. [ATTACH=CONFIG]45487[/ATTACH][ATTACH=CONFIG]45488[/ATTACH]
                          Joe, if you don't get any responses to this question, put it in a new thread.
                            • 15606
                            And show a picture with more of the lid. One doesn't assess the lid solely by the hole for the attaching stud, or at least one shouldn't do that.
