1962 Core Support Extension Rivets - NCRS Discussion Boards
  • Eric J.
    • March 1, 1980
    • 771
    Anyone have the specs and a source for the rivets that attach the core support extensions to the inner fenders? Never had to put them back in before, After Bubba chromed them he reattached them with screws. Had the chrome removed now they need to go back in. Thanks Eric
  • Robert B.
    • December 1, 1999
    • 56
    Re: 1962 Core Support Extension Rivets
    [ATTACH=CONFIG]41354[/ATTACH][ATTACH=CONFIG]41355[/ATTACH]
    Would kinda like to hear a response to this also for my '60. Anybody have any ideas?
    • Wayne W.
      • April 30, 1982
      • 3605
      They are round headed rivets. I believe Paragon has them. Probably others have too.
      • Eric J.
        • March 1, 1980
        • 771
        Looking at my 61 they look like the round head may go inside the wheel well and the crushed side is in the engine core extension side. Anyone else have an example they can check?
        • William C.
          • May 31, 1975
          • 6037
          A couple attached from my '62
          Bill Clupper #618
          • Donald H.
            • November 2, 2009
            • 2594
            I used the standard soft aluminum round head 3/16" rivets. I got them from Paragon, but others like Corvette Central sell them. They matched the originals that I removed.
            Don Harris
            Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
            • Eric J.
              • March 1, 1980
              • 771
              Don/Bill thank you! very helpful. Have the rivets on order and will update when I get them installed. Eric
              • William C.
                • May 31, 1975
                • 6037
                I've found an impact gun and ununeeded tool (like used in muffler work) with a small (3/16 inch dia) divot drilled into a cutoff shank is very useful in setting the rivits. You need a helper or a method to buck the top of the rivet while you peen the shaft.
                Bill Clupper #618
