How does the horn button work? - NCRS Discussion Boards
  • Robert K.
    Infrequent User
    • January 1, 2000
    • 29
    I don't see how the pressing the horn ring completes an electrical circuit. How does the current flow through the horn assembly? More specifically, did I break the circuit by painting the steering wheel hub?
  • Chris S.
    • January 1, 2000
    • 1068
    Re: How does the horn button work?
    Look at the 53 54 Chevy horn diagram
    It is the same
    http://www.ecklersearlychevy.com/che...1950-1954.html
    There is a specific way the center metal peice installs
    It installs with "dome" up
    Dont tighten the screws down all the way or the horn will honk all the time and scare the pee out of you when you connect the battery.
    Your missing the plastic round screw hole spacers
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Domenic T.
      • January 29, 2010
      • 2452
      Bob,
      The button completes the circuit by giving the relay groung.
      That happens when the ring makes contact with ground while the horn is depressed.
      DOM
      • Chris S.
        • January 1, 2000
        • 1068
        Originally posted by Bob Kossow (33501)
        [ATTACH=CONFIG]41337[/ATTACH][ATTACH=CONFIG]41338[/ATTACH][ATTACH=CONFIG]41339[/ATTACH]
        You will need to remove the paint on the inside of the hub.......
        • Robert K.
          Infrequent User
          • January 1, 2000
          • 29
          The classicchevy reference was very helpfull. For clarification, I believe that the horn ring itself is electrially insulated by the horn ring insulator an the three insulating screw barrels and does not actually itself complete an electrical circuit.
          Referencing Photo #20a does the Corvette use a split ring bearing seat?
          Referencing Photo #22b does the upper horn contact float, maintaining continuous electrial continuity with the Bellville washer?
          And this is where it falls apart for me, Photo #23 - "When the horn ring is pushed it will cause the Bellville washer to ground to the steering wheel center hub causing the horns to blow......make sure the center of the steering wheel where the Bellville washer will make contact is bare metal free of rust and paint." - Isn't the outside diameter of the Bellville spring always in contact with the steering wheel hub or does something cause it to float above the wheel? I guess I could understand if the upper horn contact was fixed in the insulator housing and contact was made with the Bellville washer when depressing the horn ring caused the spring to bend in just the right way, but that seems as though you would have to hit just the right spot on the horn ring to make contact. It would be a lot simpler if the Bellville spring floated above the wheel hub, but I don't see how that would work. I guess if the OD of the spring were insulated and the ID contacted bare metal when the horn ring insulator deformed the spring, that would work. Or if the ID of the deformed spring contacted the steering shaft flat washer. What am I missing?
          • Chris S.
            • January 1, 2000
            • 1068
            Correct
            the plastic is what seperates the horn from the column
            basic - the shaft is ground and the brass around the bearing is hot
            when pushed to one side the metal peice (install concave) pushes down and makes contact
            I will try to find a better diagram
