Lacquer Polish - NCRS Discussion Boards
Lacquer Polish
  • Edward S.
    • December 1, 1986
    • 514
    Lacquer Polish
    I would like to know if the 3M product Finesse-it II can be used on Lacquer paint for a light polish, hear some good things about it just want to be safe rather then sorry. Appreciate any info.
  • Thomas B.
    • July 31, 1984
    • 38
    Re: Lacquer Polish
    Disclaimer - I do not work for 3M or know anyone that does. Have you considered Perfect-It?
    I have used the Perfect-It product line on two laquer panted cars with excellent results. 3M has videos and procures online to describe use of products. Match product with correct proceedure and pad. Available in quarts and gallons from online body shop supply houses. Get pleanty of microfiber towels also.
    Tom
    Tom Brady
    • Clark D.
      • May 17, 2012
      • 8
      Re: Lacquer Polish
      This doesn't directly answer your question but here is an excellent post on detailing single stage paints.
      The Secret to Removing Oxidation and Restoring a Show Car Finish to Antique Single Stage Paints Restoring original and antique paint In the collector car hobby world, there’s a lot of interest in restoring and preserving original paint on classic and antique cars. Restoring the original...
      • Edward S.
        • December 1, 1986
        • 514
        Re: Lacquer Polish
        I should have mentioned the Lacquer Paint on this car is only about aq little over 2 years old, after paint it was covered and stayed in a heated garage since. I will not be looking to restore the paint - just preserve it. I also intend to put it on by hand rather then use a polisher. I will try the 3M web site. Thanks
        • Edward S.
          • December 1, 1986
          • 514
          Re: Lacquer Polish
          Moving it up top, still hoping to hear from some one who uses the product or from someone who does paint. Thanks
          • Thomas B.
            • July 31, 1984
            • 38
            Re: Lacquer Polish
            If you are hand applying then ingore my earlier comments, I use machine. Depending on how it was sanded / buffed out after being shot, in my opinion there is nothing like a wheel in a skilled hand to bring out the beauty of lacquer and remove those 600 / 1200 / 3000 grit scratches.
            Tom Brady
            • Mike G.
              • January 1, 1991
              • 418
              Re: Lacquer Polish
              Great stuff. Worked beautifully to hand-polish my fresh lacquer job. Removed 2000 grit scratches easily. (Again, this paint, PPG DDL, was only 3 months old, so still pretty soft.)
              • Edward S.
                • December 1, 1986
                • 514
                Re: Lacquer Polish
                Based on what I see here plus some e-mails i received it's Finesse - It for me. Still intend to put on by hand before I burn through my paint by using a wheel. I want to Thank everyone for their input. If you see me coming down the street in the next month you best put on your shades
