Seasonal gasoline blends and percolation - NCRS Discussion Boards
    • 15706
    As we move closer to the fall/winter storage season consider that most parts of the country will be switching to "winter gasoline" blends sometime in the October to November time frame.
    Winter gasolines have more high volatility components to aid cold starting, but the resulting higher Reid vapor pressure can increase percolation when next year's driving season begins. If you still have "winter gasoline" in your vintage Corvette when it gets hot next summer you will likely have increased percolation problems.
    The switch to winter blend gasoline varies regionally, so you should do some research to find when the switch is required where you live. In California, winter blend is required from November 1 to March 1, and refineries begin to deliver winter blend in October.
    It's a good idea to fill up on summer blend up to 30 days before winter blend is required to ensure that you're still getting the summer blend. Top off whatever you burn off before winter storage.
    If you want to take a deep dive into the technological and regulatory framework of gasoline go to the following page:
    Look at the right hand side and download the pdf "Motor Gasolines Technical Review".
    You only need to read a far as the distillation profiles shown on page 2 to see why vintage cars are having percolation issues with ethanol-laced gasoline.
  • Gene M.
    • April 1, 1985
    • 4233
    Re: Seasonal gasoline blends and percolation
    There are a couple stations in our area that have all gas 91 octane. Cars do run better on it. I'd assume that the all gas choice will halt for the winter. We will see........
    Some of the guys in the chapter claim that their vettes run a whole lot better without the corn juice. I've got a mix of aviation 100 and 91 no ethanol mixed about 50/50 at best in my L79 and so far is ok.
      • 15706
      I don't know what you mean by "run better", but a summer blend gasoline without ethanol has a more friendly distillation profile for vintage cars without pressurized fuel systems that is less likely to cause percolation or vapor lock. Look at page 2 of the pdf.
