1972 Ingnition Buzzer - NCRS Discussion Boards
  • Glen C.
    • July 15, 2009
    • 216
    This may be one of those dumb questions but in looking through the owners manual and the archives I can't spot at exact answer.
    While I had the driver's side kick panel out I replaced the door switch was was shot. After reconnecting the battery to test it I'm getting the buzzing when the door is open but I don't have the ignition key in the switch. Should I get a buzzing if the key has already Been removed? The buzzer stops when the door is closed.
    Glen
  • Jim S.
    • August 31, 2001
    • 730
    Re: 1972 Ingnition Buzzer
    The short answer: No, the key buzzer should not sound with the key out of the ignition switch and the door open. The following paper may help you locate the cause of your problem which boils down to a relay problem or a steering column problem (most likely in the buzzer switch itself in the column head or a lock cylinder tab that is stuck). Do you have a standard (non-adjustable) column or a Tilt & Telescoping one? The key buzzer switches are different between the two types of steering columns. The lock cylinders are the same.
    This scan (in Microsoft Word format) describes how to trouble shoot the key buzzer system.
    Jim
    • Glen C.
      • July 15, 2009
      • 216
      Jim,
      Thanks for the information. I have a standard column on my car. I'll study the paper and get to work.
      Thanks again,
      Glen
